skipnchar
Jun 04, 2015Explorer
For larger areas which it SOUNDS like you have, you can purchase EPDM material from many commercial roofing companies and create a patch glued to the old roof material and caulked at the edges or eternabonded instead of caulking (your call). I would recommend that the patch overlap the edge of the part that is damaged by six or eight inches.
Good luck / Skip
Good luck / Skip
38,706 PostsLatest Activity: Jan 31, 2025
