wvabeer
Jun 06, 2022Explorer
MountainAir05 wrote:I applied 130 to the system, the purge would not stop till I lowered the pressure lower than 95. after it purged I could barely hear a leak close to the compressor. I'm sure all the lines are leak free.
If your system had a weak unloader, you can check it out pretty easy by
appling shop air to the RV while it is not running so the governor is in cutout mode and is allowing air to the unloaders. If they are leaking you can usually hear or feel it blowing back out the intake of the compressor.
Doug might drop by in a few and correct us all.
38,769 PostsLatest Activity: Dec 31, 2017
