Update. Rudy is SUPER nice and very helpful. After putting air to the boiler I could see it was seeping into the burn chamber VERY slowly. Ruday and I discussed what it would take to try and weld this. Tons of work!! I elected to put it back together. It only leaks when I run the diesel boiler, it does not leak on electric. I have many ways to heat the coach. heat pumps and heated floors. I put it back together and added some BARS stop leak to the system. I then topped it off with boiler fluid and fired it up for 4 hours. It slowly sucked in another gallon of fluid. I did drain it some before I fired it up so there would be room for the stop leak. I never saw a drop in the 4 hours it ran. It ran hard to because I had all the zones on and it's cold here.
When it cooled down it brought the over flow tank to right in the middle between the hot line and the cold line. 2 days later it still has not leaked a drop. At this point, I feel pretty good about it. Only time and multiple uses will tell the complete story. Not sure when the coach will go out again but we will see.
Thanks again Rudy for all the GREAT advice and help. I enjoy working on most things and I learned some stuff about my unit. All good for now.
