Hi Plusit !
Like you, I have a Trail-Lite B+. I am also considering the single house battery conversion into a double, using the same technique as you did. A few questions then :
- did you keep your previous battery and add a new one or install two new batteries ?
- how long have you been using your new battery set-up ?
- has your house power been really improved ?
- do you believe in this "two parallel battery killing each other" theory ?
- even if both batteries become damn hard to check, do you recommend this doubling scenario the way you did it ?
- any other scenario to propose ?
Txs a lot
