Harvey51
Jan 11, 2021Explorer
I used the Milton inflator tool on the right for a couple of years until it started leaking air.
Note the post in the business end: it tends to slip away from the Center of the opening for the tire valve and fail to open it - allowing the compressed air to leak away. There is a black rubber ring that is supposed to hold the post in the center that seems to be worn out.
I went back to the same store to complain and they sold me an identical new one. Stupid. It leaked, too. Same problem. Turning the slotted business end gives access to the rubber ring so it could be replaced if I could find or make one of the right size I could make it work again.
I bought a new DILL USA from another store which worked. It works well new and hopefully will last for a longer time.
38,709 PostsLatest Activity: Mar 12, 2025
