RV particulars: 1998 Monaco Windsor
Driveline (Cummins 6C 8.3 300hp Turbo Diesel: Allison MD3060 6-speed WT):
Miles: 15,714 and at 32,662
Year: Sept 1998 and Jan 2001
Break Down Description: Three episodes of discovering that 12volt system was not functioning. The first experience was a Newbie "Duh", and turned out to be the doorway 12v disconnect switch being bumped (and switched off) while unloading after a trip. The two noted above were a result of equipment failure.
Symptoms: All 12v electrical inoperative.
Effect: house lights, thermostat, appliances, etc., without power
Cause: failure of continuous duty solenoid located in main automotive panel.
Outcome: first failure replace under regular warranty, 2d occurrence covered under extended warranty and fixed using an upgraded heavy duty solenoid. Work was done by my RV dealer.
