RV:2005 Sportscoach Elite 401TS
Engine: Cat C7
Transmission: Allison 6 Speed
Symptoms: Application of exhaust brake and service brake would result in a warning light and a message that said, "Brake Fuse 5.6 volts" "Below Threshold 7.0 volts." Exhaust brake is equipped with Brake Switch controller.
Exhaust brake did not activate and transmission did not down shift. Exhaust brake light on panel did not come on.
Found later that brake lights were not coming on either.
Actions: Called Coach net and they put me in touch with Freightliner Oasis facility in LaCrosse WI, about 80 miles away. Since service brakes were working I could drive there. They were open even though it was Sunday but they could not get me in as it was about 2:30 when I arrived. They got me in 7:00 on Monday morning and finally isolated the problem to a shorted wire going to the Brake Switch module. Took the Brake Switch module out of the circuit till I get home and can find the short and all is well. Four hours trouble shooting time, etc for a total cost of $517.
