cencerrita
May 21, 2021Explorer II
quasimatter wrote:
One more question on my 28A - I am trying to load up a scooter (350LB) on the hitch - while RV data indicates much higher towing capacity, the hitch showed two different numbers (see pictures below).
First the data from Ford - Max GWVR for E450 is 22,000 LB
As per labels on 28A - GWVR for unloaded 28A is 14,500 LB
Max Cargo Capacity - 3,127LB Lets say liquids are 342LB (as per label) and passengers and other being 1000LB - that leaves almost 1800LB tongue weight remaining (not to mention additional (3000LB+ remaining to get to E450 stated GWVR of 22,000LB).
And then the following:
First I noticed the stock hitch provided by Cruise America was rated only 200LB tongue weight (see picture below) (Sorry - can't attach picture - will add picture later).
However, this picture seems like a sticker stuck by Cruise America on top of official sticker underneath. So I peeled it off and found a 500LB/5000LB hitch manufacturer sticker (see picture below) (Sorry - can't attach picture - will add later).
Has anyone else noticed this? Which number should I go by? What is the weight others have towed with stock Cruise America hitch?
Just remember how far back you scooter will be from the axle and the lever effect it has increasing the axle weight. You should have no problem as long as you load properly and get weight foreward - we always carried heavy stuff under the table, front bench seats etc and my tools under the front seats etc. No problems with our scooter of 300 lb with out 27G although if left on for overnight stops I did put a 4 x 4 piece of wood extra support under the scooter rack. Weight of 2 people sleeping in the rear at night is extra.
38,774 PostsLatest Activity: Apr 26, 2026
