For those of you that have taken the time to re caulk your RV windows did you remove the window frames or just re caulk along the outside edging? Thanks for your input.
Have to admit when the small window above sink started leaking and I got the quote and time to take it out......I put clear silicone around the edge on the outside. Can't see it and several years later no leaks.
