I just changed out my head lights to the Cree 40 watt 9600 (H-11) lumens the are plug and play I put them on both high beams and low beams. I also wired my head lights so when the High beams are on the low beams stay on. What a huge difference, you will need a relay and 2 diodes, along with a 30 amp fuse, the draw when all 4 are on is 12 amps which is less then the standard bulbs they were drawing 12 amps with just the low or high beams on. They where wired before so when you turned the high beams on the low beams turned off. Well worth the investment about $130.00 for all 4 lights.
