X12AEsq
Jul 20, 2014Explorer
randallb wrote:
We owned an 08 Vacationer XL and the fix to your problem is around $20.00. I used a Battery Tender Jr, .75A maintainer.
Did you leave the batteries wired in parallel and connect the charger across both of them them as a unit? I suppose since the batteries are in parallel, it doesn't matter if you connect the charger to the positive and negative pole of a single battery or positive of one and negative of the other?
38,763 PostsLatest Activity: Dec 28, 2025
