drf004
Jun 07, 2013Explorer
I re-coated the roof of our 14 year old Georgie Boy Motorhome last year with the 2-part Dicor product. It has held very very well! No flaking, no lifting, nice and tight. The two part system is really easy to use just be sure you do not apply the cleaner part in full sun. As far as using a pressure washer, mine was a 2200psi unit and worked great. I was careful and it cleaned it beautifully!
When you tape the plastic to the sides do not use standard masking tape! Once it gets wet it is very difficult to remove, use blue or green painters tape instead.
Good Luck!
Good Luck!
38,782 PostsLatest Activity: Sep 18, 2026
