the_armadillo
Jun 27, 2014Explorer
Had a similar broken bolt on my 5.4 Triton F150. Spray around the broken shaft with a good penetrating lubricant and drive it thru a number of heat cool cycles. Respray and do it again. I personally use Aerokroil. When I removed the manifold, I was able to remove quite easily with vice-grips. Tapping (good hard tap) on the other bolts prior to removal as suggested is a very good idea too. Good luck. My truck no longer clatters on cold start after repair.
38,707 PostsLatest Activity: Feb 18, 2025
