s79vette
May 25, 2014Explorer
A few years ago I had the same problem with our F53. there was 12 volts at all the panels so it was deceiving. 12 volts will pass through a wire as small as a hair as long as there is minimal current. on the frame rail behind the front pass. tire there is a 12 volt solenoid that has to energize to supply power to engine 12 volt panel and start system. mine had a loose cable on one of the posts so nothing would work but everything checked out good.
38,709 PostsLatest Activity: Mar 12, 2025
