MrDoneIt65
Sep 13, 2015Explorer
When I did my Norcold recall Amish coils replacement I put electrical tape around the wheels on my motorcycle jack. I pushed the fridge out from the back of the compartment after disconnecting everything. When I got the fridge on the jack I rolled it to the middle of the kitchen, put a piece of cardboard on the top and then jacked it up so it was against the ceiling. Read the instructions. You have to clean all of the old caulking off the fins that are in the back of the fridge. There were 4 bolts in the coils. Note what it says about the cooling fans. Even though they are 12 volt they can be hooked up backwards and will not work if they are. I found out that my cooling fans were hooked up backwards. No one had ever touched the refrigerator except those who originally installed it and the technicians who did the recalls. My original coils blew out at the point where the heating tubes and the recall mechanism were attached. As the other writer said, I run my Norcold on 5 and it will even freeze ice cream now . Which it never would before. I couldn't even keep popsicles for the grandkids because they would melt in the freezer when the fridge was on 9. Do not be afraid to do this real fix. The Amish coils are heavier, they are double coiled and they work a whole lot better. And they are MADE IN THE USA! Good Luck!
38,707 PostsLatest Activity: Jan 05, 2014
