I’m having a problem I hope some one out there can help with. My Onan 6000 quiet diesel generator won’t start unless the ignition key is in the running or accessory position. I could run an always ho...
Thanks for responding The issue started when I accidently left the key on and drained the batteries. I charged them and they tested “good condition” at 900 cca (rated 950 cca new). The gen will start and stay running under these conditions: 1. The ignition is in the ACC position 2. The ignition is in the on position. 3. The main engine is running. 4. The ACC start switch is pressed and held down. Once tge emerg start switch is released, the generator will stop
