Netboy503
Aug 17, 2016Explorer
wildroot wrote:
My RV does not have automatic levelers and getting it really level is most times a real problem.Does it harm the operation of the Refrigerator if I am not at trus level.And if so, is there a time limit on how long it can be unlevel without doing damage?
This is what the cooling unit of your RV fridge looks like:
Your RV should be level enough that the liquid refrigerant can flow down the zig-zag tubing by gravity. If your parked RV is out of level enough that the liquid refrigerant can't flow downhill through that zig-zag maze and gets trapped, damage will occur to the unit.
As others have said, if your RV is level enough so that you feel comfortable while inside, then the refrigerator should be fine. You can see that you would have to angle the fridge quite a bit for the gravity flow of the refrigerant to be impeded.
The situation that could cause damage is if you are traveling with your fridge running, and you park on a relatively steep grade while heading off on foot for sight-seeing or shopping. If you do park on a hill, remember to turn off your fridge until you get back.
Also as others have said, don't worry about the fridge if running while you are driving -- the constant motion prevents the liquid refrigerant from accumulating in the zig-zag tubing.
38,708 PostsLatest Activity: Mar 04, 2025
