donran
Sep 12, 2005Explorer
What a trip, put water in the RV, no leaks things actually worked. Few flushes and what looked like a dirt bowl flushed down, cleaned itself and sealed. Little weird when your family lines up to use the RV toilet. Found some sanitizer, 8oz does 40 gallons. Of course no one is happy because they don't have hot water, propane is next. The weight of 40 gallons of fresh water (320 lbs) really presses down on the rear duals. Got to find a way to check pressure and fill tires. The dealer put two new tires on the back because one of them went flat and the casing cracked. I found out I don't have an inverter, just an ac inlet that connects to a simple 20 amp charger with a 12.7 output voltage. Think I'll just by a small inverter for the 19" TV. The only generator I have is a 6500 watt Coleman Powermate that is the second loudest generator ever made and known for throwing cranks. Needs a tractor muffler and a spark arrester. When you can actually wash and poop in your RV it makes you feel kind of good.
38,708 PostsLatest Activity: Mar 05, 2025
