ellenjackson
Feb 16, 2025Explorer
You're right—new engines can be shockingly expensive! The Cummins ISX15 engine, depending on the specs, can cost anywhere from $40,000 to $75,000 brand new from an OEM dealer. Other models like the ISX12 or ISB6.7 tend to be a bit cheaper, but they’re still a hefty investment. A lot of fleets and companies that use Earth Movers Equipment opt for rebuilt or remanufactured engines to cut costs. If you're just curious, checking with a Cummins dealer or a heavy equipment supplier might give you the most accurate pricing.
- StirCrazyFeb 17, 2025Moderator
aside from this post being 10 years old, national truck parts sells then for about 25k, they say new but I suspect it is just a used in good condition.
38,775 PostsLatest Activity: May 14, 2026
