ArchHoagland wrote:
There was a brake recall on the Bosch brakes that are installed on these chassis. You need to find out if that was completed.
The calipers wouldn't release and would drag.
Have you weighed the coach yet and set the tires pressures to the tire makers recommended pressure for your weight?
I will check to see if recall was done. As for weight and tire pressure, Still loading and unloading to figure what we really need. We sold our homes and now are living full time in the MH. We won't head south until September. I'm hoping that the dealer that we bought the MH from sent us off with the correct tire pressure. We've only had the MH for about a month. Much to learn. We did make a few changes that cut some weight. removed the heavy tube TV's (replaced with flat screens) and one of the couches that was a hid-a-bed.
