Racorman
Feb 22, 2018Explorer
enblethen wrote:
Clean all pivot points with carb cleaner. Inspect the drive motor for tightness. Lubricate with motorcycle type dry chain lube.
I first look in my garage to see what's available before I go out to the auto parts store. I do have a can of aerosol engine degreaser which removes grease and grime and leaves no residue. Also have a can of WD-40 PTFE spay dry lube which really works well on my gear teeth for the slide outs. I found a replacement motor for $40 which I'll use if I have to.
Thanks again enblethen
38,707 PostsLatest Activity: Feb 18, 2025
