tropical36 wrote:
Richard_999 wrote:
My 2000 REXHALL Rose Air steps work like they should , EXCEPT , they do not RETRACT all the way.
The ALMOST make it , but there is about6-8" of step , still showing.
I have replaced motors before , but never experienced THIS problem.
ANY IDEAS ?
Richard / S. Carolina
2004 CRV
If you pull the pin, thereby disconnecting the motor drive, will they then retract, as designed. Just trying to figure where the problem might be here.
Disconnect the motor and move the steps manually to verify that the steps move without binding.  I expect that they are binding somewhere.
