Dirtyrhoades77
Mar 06, 2021Explorer
valhalla360 wrote:pianotuna wrote:
I would jump right to a 48 volt battery bank.
Agreed, once you diverge from 12v may as well take good advantage of a higher voltage.
Also, keep in mind for the spacing, that the 12" manufacturer spec you mention is likely based on the condenser being completely outside with no other restrictions. If fresh cool air can only enter from a relatively small slot from below, it may not meet the needs. Talk to the manufacturer and explain exactly what you are doing.
Good point on the spacing. The opening would be the full 12" as the entire bottom would be open to the ground other than the two supports it would be sitting on, maybe unistrut, but maybe that's not enough. Surely any manufacturer would be against anything out of the norm so it's not worth the effort to explain it to them. There are guys on youtube that have done it to their Class As, and one manufacturer is even offering it as an option on a new model. Stuffed right into the compartment below. It's pretty cool.
As for 48v, I can see what you guys are saying, but if I go 48, I'll then have to get a 48 to 24 converter for the fridge, and that's another component, and it's $150.
My system probly won't ever go over 2000w, so I won't be outgrowing 24v, so I can't see any real advantage over 24.
Maybe 48v mini splits are easier to find at the moment? Are 48v alternators easier to find? What other advantages are there besides more headroom for expansion?
38,766 PostsLatest Activity: Jan 10, 2026
