Re: Need help 2000 rexhall aerbus
Is the battery charged?
If yes, you can jumper the two large posts on the battery disconnect to energize system.
If yes, have you checked the control fuse?
If battery is not charged, try using the auxilary start button at the same time as battery disconnect enrgize button with engine running.
