midnightsadie wrote:
got a good battery?"
TWO Batteries Actually. Look at Owner Manual Page 21. Battery on the left side of the chart is a "car battery." Battery in the Center Column is the "House" or "Coach" battery. Deep Cycle/RV/Trolling Motor Battery. The top three items in that center column have to be present and good, along with connections mentioned above, to even attempt to crank the generator. Power Center (first item on the list) should work lighting etc on its own but probably will NOT crank the generator.
I looked at Your Posts. Chef! Recipes! Where are you Camped and When's Dinner?
Glad to help, keep in touch.
