Jrork
Jun 11, 2015Explorer
Here's the last update. Once we removed the pump we found the rubber hose from the actual pump to the sending unit housing was in horrible shape and was deteriorating. The bottom of the tank had all sorts of pieces of rubber from it and what was left of the generator pick up too. It too was falling about in my hand. Swapped out the pump and shazaam, it fired right off and holds pressure versus how it use to be where the pressure would bleed off almost instantly after you turned the key off. Thanks again everyone
38,765 PostsLatest Activity: Jan 09, 2026
