Well, I'm please to report after removeing material from the cabover ceiling I found two wires that had been tucked away, I attached a circuit tester to the wires and turned on the headlight switch and wallah, I had a very pleasant surprise. I had power to the wires. I just saved myself a lot of money and time,, now off to the store and buy clearance lights and material to repair the cabover ceiling and I',m done. I found I'll need to replace the cabover flooring also but I'll replace that with marine grade plywood. Thank you everyone and thank you Brian for your great suggestions. :B
PS: Now do I simple wire all five clearance lights together in a line to the main wiring. :h
