Re: O.K. to use a battery terminal disconnect switch?
What is probably happening is that the memory in the ecu for the engine, the clock and memory in the radio and any other gadget hooked to the vehicle battery is draining it, specially if the RV sits for prolonged times with out being used.
Place the disconnect switch in such a manner that it does not create a hazard when disconnected.
