bingoldsby
Sep 16, 2014Explorer
Thanks for the info. I do know where the points/cond. are located. There's a metal box that is held in place by a little wire bale across the top of it. It's just that the adjustment of the points must have to be done either by the braille method, or by pulling the generator, as suggested, not an easy task. I thought that with the points needing to be a fairly regular maintenance routine, it would be possible to make the inspection and gapping adjustment without the gen. removal. I'll look a bit further.
Thanks again.
Brian
Thanks again.
Brian
38,768 PostsLatest Activity: Nov 21, 2015
