MSHappyCampers's avatar
Feb 21, 2013
Re-piped kitchen sink
After we bought the Windsor we noticed that the water flow from the main kitchen faucet was very low. The bathroom and shower was normal. I checked the water piping under the sink and got quite a shock! Monaco had run the main cold water line through the water filter, then out to the sink faucet, instant hot water faucet, and icemaker. No wonder the flow was low since the water filter only passes 1/2 gallon per minute!
After thinking about it, I realize that they did it this way because there was not a separate faucet for the water filter. I know this was not a million dollar coach but you would think they would have spent a few more dollars and put in the separate water filter faucet!
To solve the problem I decided to remove the instant hot water faucet, which did not work anyway, and install a separate faucet for the water filter. I then reworked the piping to put the main kitchen faucet direct on the cold water supply pipe, and have the new faucet and icemaker on the water filter. Problem solved!
BTW, I was amazed at the wide range of prices on the small faucet for the water filter! They went from $19.95 all the way up to almost $100! I found one for less than $20 that looks nice and does the job for me!:B
