SuaveGatoExplorerFeb 20, 2016Plumbing wrench? Spanner wrench? HELP?Hello, trying to see if there is a special wrench for the compression fitting on the black plastic plumbing? My shower drain down-pipe has come lose from the "J" pipe and I can't get it tight enough...Show More
SuaveGatoExplorerFeb 21, 2016liborko wrote:The white nut is a combination sealing ring and nut in one piece. You can also get a separate sealing ring if that is what you have.P-trapThanks, guess it's called a "P trap" not a "J-trap".
Related Contenttire wrenchPlumbing ManagementPlumbing ConfusionPuzzling Plumbing ProblemDog House Spanner Key
