TIMETOTRAVELExplorerJun 24, 2014problem with right front turn signalI have a 2003 Tiffin Allegro Bus, when you turn on the head lights the right signal light... lights up on the dash , even without pulling up the blinker arm, but not on the outside. If you do pull up...Show More
rongtamwExplorerJun 24, 2014If the directional light bulb is in the same housing as the headlight bulb you could have a ground problem.
Related ContentAtwood water heater problemTurn signal problem...Troubleshoot fridge problem...Turn signal problemTV antenna signal problem
