thetundrawolf
Aug 31, 2014Explorer
donrebyct wrote:
Check out this forum on Foamie tiny trailers for an alternative rebuild.
http://www.tnttt.com/viewforum.php?f=55&sid=183568eb64037679cd66dbe91394a956
It's well discussed and detailed about building a camper with foam. Foam, especially the way discussed here, is rot proof, lighter, easier to work with, and cheaper. The idea is to minimize any wood. You can use fiberglass (more expensive, toxic, and harder to use), or the favorite on the site of canvas and glue (or paint) to cover the foam.
Save all of the cabinets, appliances, windows, etc that are salvageable, then strip it down to the truck frame. You can change the layout to your needs, get rid of the overhead bed if you desire, and rebuild it any way you want to fit your needs and budget.
I would do this if I was in your shoes. Take this as an alternative idea. Good luck.
Don
I will consider it, thank you. How strong is it? I am brutal on my stuff, going offroad and whatnot. In fact my RV will be a 4x4 soon, actually, which means lots of stress and sway.
38,709 PostsLatest Activity: Mar 12, 2025
