I replaced our sofa with a single recliner on a swivel base. Couldn't find a suitable dual reclining sofa at the time. As my wife must sleep in a recliner, this fits us very well. I still use a lawn chair in the asle as the second chair. Caution: some of the hold-down bolts for the OEM sofa do not drop to the ground but remain inside the flooring with no way to remove them. Caulked the bolt holes that I could reach. I built a sturdy, small, solid platform that is necessary when the slide-out is extended to provide a stable footing for the round chair base. Works very well. When under way, I place 2 tie down straps around the recliner arm to ensure the chair remains up rignt. BTW, it was a challenge to fit the chair into the doorway. Not sure if it will get out the same way. It is a very large, very comfortable overstuffed chair.
