Chuck_Sances
Aug 13, 2014Explorer
Try cleaning the aireator on each faucet. They could be full of sediment from the water heater. I think you said that you were in the Arizona area before your trip and there is very hard water there causing sediment in the tank. also there is an attachment type yellow wand which you use to clean out the water heater tank by inserting in the drain hole and attaching it to a water hose. You will be surprised at the amount of sediment that will come out. First just unscrew the aireator on each faucet and run the hot water water without it to see if clogged. Chuck
38,707 PostsLatest Activity: Feb 18, 2025
