samert
Apr 04, 2018Explorer
I just replaced our Dometic RM 7732 side by side with an Insignia NS-RTM10BK8 9.9 cubic foot model. The Dometic measured 32" wide by 59" tall and 23" deep and the Insignia measures 24" wide by 59" tall and 24" deep including doors.
The Dometic was flush to the cabinet and I installed the Insignia box flush also but the doors stick out about 2 1/2" but that's fine because there is a pocket door next to the fridge that sticks out the same. The wife is happy because she gained another 8" wide closet next to the new fridge for her broom and and the Dyson stick vacuum hangs off the back wall. my limiting dimension was the height because I have the power distribution center below my fridge and I couldn't make the opening taller.
The new unit is smaller dimensionally but it's about 2 CF larger inside so unless you have room to open the width on the hole you probably will not find anything to fit exactly so don't rule out the smaller apartment size refers.
38,712 PostsLatest Activity: Apr 06, 2025
