alliemac9
Jan 09, 2018Explorer
OP here. Wow - thanks for all the input so far! I hope to be able to respond more specifically and ask some clarifying questions, but am buried with some stuff at the moment and then will be traveling briefly.
It will (hopefully) be attached to house, matching materials, frame built, siding exterior, etc. So, closed in with typical (but oversized) garage door. Am thinking of a double man door on back to allow riding mower out, and ventilation, etc. And half the reason for the laundry rough-in is to justify a cleanout to use as a dump station. There currently is no exterior cleanout to access.
The current place I store it has a 10'W x 14'H door, so I know all about the narrowness issue and I will likely feel spoiled with a 12'W door. Actually, where I store it now is pretty insane in all dimensions. I have to creep in, putting it in park regularly to pull mirrors in and out as I pass through the door opening. And then stop within a quarter inch of the overhead bunk hitting an upper wall while being perfectly perpendicular to said wall, or the door won't close. :D
If anyone in CO has recommendations on contractors, etc. I'm all ears - still working on that part.
38,778 PostsLatest Activity: Jun 03, 2026
