Trying to install a new RV Mask/Bra and am not sure how the nails provided works on a fiberglass Class A Motorhome. The instructions states that I need to drill hole into fiberglass and screw snaps d...
Those "nails" are called pop rivets. You drill a hole the size of the large end, insert the rivet thru the snap and into the hole you drilled and use a special tool to pop the long portion of the pop rivet thru the large end causing it to swell and lock the snap into place. The pop rivet tool can be purchased at any home center.
