I have a 1994 a winnebago brave 24’ and need someone’s opinion on this. I’m not getting fuel to the TBI carburetor on the Chevy 454 motor. I have changed the fuel filter the fuel pump rebuilt the ca...
With it quiet turn the ignition switch to run and listen for the fuel pump to run for a couple seconds. If it doesn't run you could have a bad fuse, fuel pump relay, or a bad pump.
It's been too long since I owned my 95 Brave on the Chevy chassis so I don't remember what fuse or relay controls it but I do know they are under the dash. I remember mine was you lift up the dash and the fuses and relays were down next to the steering wheel.
Have you cleaned the injectors? Have you tried pouring a little gas down the throttle body and tried starting it?
I think the Chiltons C-30 box truck manual shows the wiring diagram or search online for the wiring diagram.
