Desert_Captain
May 21, 2016Explorer III
Re securing the cab/cabover joint/seam
Like most Class C 's manufacturers, Nexus uses screws to connect/secure the cabover to the top of the cab itself.  The problem is that over time, miles and having hit just about every pothole between Arizona and Maine those screws tend to work loose or fracture.
This leaves a bit of movement between the cabover and the cab. After a couple of years this movement became more pronounced so I pulled the plastic molding down and tightened every screw, replacing a few with larger and longer. This band aid solution worked for a year or so but was not the long term cure I needed.
I ordered the three replacement plastic molding pieces from Nexus and ended up with three additional pieces that are enough to redo the entire cab (I'll save those for some future needs).
About $40 worth of hardware and couple of additional tools and I was ready to go to work.
Taking down the molding and opening up the seam/joint was straight forward enough and happily all of the existing screws came out without complaint. Using a Cobalt drill bit (which went through the steel like the proverbial hot knife through butter), I re drilled each hole going all the way through/out the top. I replaced every screw with a 2" #10/24 SS machine screw (with large round flat heads), and added flat washers and lock nuts to the top.
Before I could torque them down I had to place clamps on either side of the new bolt to tighten/flatten the steel top of the cab. I worked from back to front alternating from right side to left finishing in the center of the cab. Once they were all torqued down I used a hack saw to trim off the excess bolt right at the top of the nuts.
The last step was to install the new molding and for good measure I replaced all of those screws as well. Buttoned everything up and took the coach for a test drive and Wow! what a difference. There is zip, zero, nada, no movement of the cabover with not a squeak top be heard.
Structurally this is a 1,000% improvement from the original, perpetually loosening screws. I know through bolting takes more time/money but it is definitely the right way to go and frankly I was disappointed that Nexus used screws in the first place. I can't see how those lock nutted bolts will ever loosen up but only time will tell.
