nwtguy_ExplorerJun 16, 2013Squeak between chassis and houseHi, we have a 2000 30ft Tioga c-class which just past 100,000kms today. Over the last year it has started to make squeaking noises from between where the chassis meets the house part of the RV when dr...Show More
kodiakdonExplorerJun 17, 2013I had the same problem with my 2001 Jayco.The screws that hold house to cab came loose, I replaced screws with bolts.
Related ContentSqueak Noise Rubber Seal Cab Chassis ?belt chirp/squeakCan you name that sound (squeaking)?Squeaking From MotorMystery squeak found
