Rollnhome wrote:
Tie the strings to the spring. Do not loop them through the spring. You should have 4 separate strings. 2 on each side of the spring. Center the spring in the top "rail" then follow stringing diagram.
You could loop them through the spring but tie them so they do not slip. They need to be fixed to the spring.
So NOT magic. I didn't tie them and don't relish the idea of taking it all apart to "fix" again.
Is this what I get for not watching YouTube? I am so old I would rather read--isn't that humbling? Especially since I skipped the knot part? So now my brain doesn't hold the WHOLE ENCHILADA either?
I wonder if the strings in the set are not the same length though? And why would only one string slip?
If not Magic still a Mystery...at least to me.
Thanks...
