DrewE
Oct 31, 2021Explorer III
I took my (32' 1998 Coachmen) class C over many Alaskan roads, some of which were comparatively rough and rutted. These things are of course somewhat subject to personal interpretation, as far as what makes a really bad or rough road. I did drive to Eagle, Deadhorse, and McCarthy, which means not sticking to merely the paved roads.
The structure survived without any significant problems directly related to the hard use, though I definitely do think it is rather worse for the wear. There do seem to be the start to a few little buckles, etc. in some of the sheet metal I-beams under the floor, which I've been thinking maybe ought to be reinforced; I don't know if that's directly attributable to the Alaska trip or just typical for the age and construction and whatnot. In any case, while I have absolutely no regrets about taking the trip--it was a wonderful experience overall--I also doubt I'd repeat it with this motorhome, nor do I think it would survive many more such rough trips very well.
The actual ground clearance of my motorhome is pretty decent. The departure angle is not very good, due to the long overhang, but for those roads that was not much of a concern as there are not many sudden changes in ground angles. The only places I've scraped have been things like gas station entrances or driveways or railroad crossings that slope suddenly up from the road surface. The plumbing in my unit is pretty well protected within the structure; it doesn't really hang down loose underneath.
Nowhere have I had particular trouble with steep inclines. I suppose a steep enough incline could be a problem, but anything remotely like ordinary hills, even steep ones, are fine if taken slowly with appropriate caution and care.
The motorhome most certainly does not come anywhere near the off-road capabilities of a Jeep or even a typical pickup truck, but it's more capable than it might at first appear despite the limitations. At least around here, the overall physical dimensions--the height and width and poor turning radius associated with the legth--are probably the biggest limiting factors for where I can go. Many back roads have overhanging tree branches well below the 11' clearance I'd require. Of course, in other parts of the country there may not be many encroaching trees at all.
38,783 PostsLatest Activity: Sep 24, 2026
