bobman wrote:
With two engines of identical displacement it has to be different boost levels or the hp is rated at a different rpm or some combination of those two factors
Fuel delivery has to match the combustion volume to keep the valves in the correct temperature range
not really what the op was talking/asking about but first time in my life I heard that
quote:Fuel delivery has to match the combustion volume to keep the valves in the correct temperature range
can you explain how this works? how does one correct the temperature of the engine valve and how does one know when its incorrect?
