j-d wrote:
So I put the wheels back on and tried backing/stopping and forward/stopping. Seemed fine, so I drove it. I had upgraded from 2002 brakes to 2012 brakes and immediately found the pedal was OK and the braking was excellent.
So can you make a couple controlled short moves/stops and see how it's acting? Then a short test drive? I suspect you'll be OK. Seems to me we don't realize the racket the H-B makes when the coach isn't moving and all we do is focus on the noise.
that sounds like a plan! my RV is in my barn out in a nice flat field! what could go wrong?? I'll bleed em one more time with the power bleeder then try it out in the field. Maybe if it doesn't work, i'll just leave it there!
