Desertcat921
Feb 12, 2014Explorer
The problem here is that not all parks are 240 VAC for 50 amps some just use 120 paralleled to both hot legs so neutral carries the whole sum of the two legs. This means if the neutral is smaller and you are using heavily you may have an overheated wire ....Jerry
38,766 PostsLatest Activity: Jan 10, 2026
