beaubeau's avatar
beaubeau
Reading propane gauge
A friend has a new used RV and it has a gauge on the propane tank.
It has an electronic display inside the RV, but how do you read it from outside, at the gauge itself.
This is what it looks like...
">gauge
  • Thanks for all the help! And that thread was very helpful.
  • Tom_M wrote:
    The gauge pictured is a float type gauge. If the tank is empty the pointer is likely behind the the piece that the wires attach to which is the sensor for the indicator inside the coach. If the tank is not empty the float may be stuck.
    I agree, in the picture it looks like the red pointer might be in the lower right side and might be stuck. JMO
  • The gauge pictured is a float type gauge. If the tank is empty the pointer is likely behind the the piece that the wires attach to which is the sensor for the indicator inside the coach. If the tank is not empty the float may be stuck.
  • RoyB's avatar
    RoyB
    Explorer III
    I got one of those cheap green scale gauges from AMAZON something like this one for each of my two tanks. It seems like it always says it is the green until all of a sudden it goes to empty. Does not do a gradual change in reading as it is being used..
    I usually run my hand along the tank in the morning and I can feel the cool zone where the gas level is. Alot of times in the morning you can actually see the sweat line...
    My real problem is I always turn off the tanks when in travel and I forget which one I am using. I'd like to use the same one until it goes empty. I guess I need to hang a D-link snap ring hook or something on the valve of the tank that is in use.. Then at my age I'd probably forget if the hook means it is empty or the one I am using - go figure...
    Roy Ken
