Jul 25, 2016Explorer
Squealers wrote:
Mark,
It was working fine. We checked it prior to departure. Something happened 25 miles in. I'm thinking a turn put tension on the cables even tho they were set to the proper slack, and jammed the brake peddle.
I'm thinking the culprit was the brake-away cable. But they were both jammed tight and can't be moved in or out. I disconnected the cables from the brake pedal but they are still jammed.
Something had to happen to activate the break=away cable. Strange that the toad pedals won't return to normal if both cables are disconnected.
