willald
Jul 28, 2016Explorer II
Dutch_12078 wrote:
I don't understand how the breakaway cable could break the brake pedal. The cable is supposed to have a link installed that breaks loose with just a few hundred pounds of force if the vehicle breaks loose. I can understand the breakaway cable getting caught on something and applying the brakes enough to fry them, but not physically breaking the pedal.
If the metal link on the breakaway cable that is designed to break loose with just a few hundred pounds of force was not used properly in the connection, I can definitely see how this would happen. Just hate that this had to be such an expensive lesson for Squealer.
Lesson to be learned: Even when you have something installed and set up professionally, you still need to understand how a system works, and make sure you are hooking it up correctly and that the installer did their job right.
Will
