Hiker_01
Apr 03, 2017Explorer
I've had mine for over a year now. Really like it. Some "down-sides" to consider in your planning.
a) Because of what it is designed to do (absorb kinetic energy and convert it to breaking), it is much heavier than many towing systems. Also, does not "fold-away" and stow attached to motorhome. This means when you disconnect your toad, you also have to disconnect and stow your tow bar.
b) I have found it to be a bit tempermental when disconnecting (this may be true with all tow systems). You have to be pretty well lined up when pulling the pins, otherwise they are impossible to take out.
Otherwise, I like mine. I like the concept, and even though it is a bit of a pain in weight, I'm pretty sure it will last a long time.
